h22 swap
RE: h22 swap
ORIGINAL: DA KID RYU
1) How much horse power does the h22 head increase without turbo....
2) Why do u need new valve cover
3) ecu which one the f22b1 vtec one or the h22 one...
4)why do u need a new water pipe and thermostat...
2) why do you think? (what does the valve cover bolt to...)
3) whichever head your using. Btw this is not easy, and since your even asking that question I would guess you wouldnt be able to do it at this juncture in time.
4) why do you think? different head...
RE: h22 swap
ORIGINAL: nafango2
1) not enough to make it cost-effective. like 15. if that.
not thinking of doing it myself or right now if that but i like to learn all this all....
curious to learn bout this topic....
So different head more friction aight
this is what is getting me confused sorry
your not using the same valve cover..
i got a f22b2 im not using the same one or what...
RE: h22 swap
^ Kid - start reading and getting to know things before asking such general questions.
Go over to www.honda-tech.com- sign up, read, read, read. That's the best advice I can give you. If you don't understand it, re-read it again.
