h22 swap into 96' accord
Old 04-07-2007 | 03:38 AM
Go Honda GO
Default h22 swap into 96' accord
how do i find out which h22 i need, and i looked at a website and it was sayin something about the vin number, im tryin to get this show on the road
Old 04-07-2007 | 03:58 AM
03Sleeper's Avatar
Default RE: h22 swap into 96' accord
The VIN number should be in the lower corner of the windshield...usually driver's side.
Old 04-07-2007 | 03:20 PM
poser_pilot6
I dont know that you should worry about the VIN on the donor car. What car do you have? Are you looking for a Prelude from a junkyard, or going for a JDM motor?
Old 04-10-2007 | 01:56 AM
Go Honda GO
i was gonna get one of car-parts for cheap, but my friend said something about an incombatitbility that ends up in blown valves
Old 04-10-2007 | 02:47 AM
Shadow1992's Avatar
you need an h22a1. The vin number is needed for inspection purposes to legalize your engine for the road. as far as that incompatibilty issue..the only one you may have is going from sohc to dohc..which would require the donor car's ecu, or a reflashed/programmable aftermarket ecu. even then you shouldn't end up with blown valves unless the engine was in poor condition and you over drove it.
Old 01-31-2012 | 05:42 AM
silence007's Avatar
tenth vin is the year, I am pretty sure any way.
mjj97
03-14-2012 01:04 AM
94accordexl
04-22-2009 09:24 PM
juansosa57
07-02-2007 09:59 AM
blksniper2000
06-28-2007 10:35 PM
marbro
05-12-2006 05:29 AM
