H22A Swap
RE: H22A Swap
Thanx for the info.I got the complete deal of the year.My H22 comes with the trany wire harness & ECU. Lookin at what u said i might need to get stonger axels and from other source i might have to get a prelude headers/down pipe exhaust. Will the header/exhaust system bolt on perfectly to my 91? Cut wires??..I'll check that out. Thanx again
RE: H22A Swap
no your current manifold wont work, its not that you need stronger axles to work with the motor...the problem is your accord axles are not compatible with the prelude transmission. so you could use your accord transmission, which will bolt up to the h22, but i would not recommend..... or you can use your current axles as cores and get some refurb axles for a prelude nice and cheap.
lightshow
lightshow
