h22a1
h22a1
so ive been working on getting a swap done with the JDM h22a but ive ocme across a h22a1 locally for 300 buckks...this is a quote from the CL posting "I have an h22a1 that has a bad block. it had a rode knock so i took it out. Its missing distrib, and intake man but i do have a jdm h22a manifold that i don,t want you can have it"
i know it would need alot of work but hey its 300 and i wouldnt have to worry about shipping...
do you think i could use my f22b block?
and the h22a1 is USDM right? OBD1 ?
You could use your f22b block with some work, but it wouldnt make as much power as just a h22.
h22a1 is usdm.
in my opinion it would probably cost just as much if not more to fix that engine than it would just to buy one that is working.
h22a1 is usdm.
