head swap h22a4 into f22a1
Old 09-17-2008 | 09:59 AM
jcocker03's Avatar
Default head swap h22a4 into f22a1
I have a few questions about doing a head swap on my car, its a 91 lx with f22a1 and ive heard one of the best options would be using a h22a4 head.
what kind of power increase am i looking at?
also, what do i all have to swap with the head to make it work?
Old 09-17-2008 | 10:27 AM
falkore24's Avatar
Default RE: head swap h22a4 into f22a1
Do a search .... if it doesn't work, look up finch13 on the top 10 list to the right and use the search in his signature.
Old 01-20-2009 | 09:08 PM
Omegastorm99's Avatar
The swap from what i got is quite easy you need to fill two oil drain holes in the head and use the F23 head gasket, also the you need a H22 water pump but you have to use the F22 water pump housing and the H22 gears and guts. Its soooooooo much better then swapping motors and i believe the compression is still quite low, but the advantage is more cams and timing and also better tuning capabilities. i think you also need the H22 ECU and harness. the people that did it used a non vtec block
Rashaun Fraser
Canada, Over Seas & Elsewhere
08-04-2013 05:04 PM
91accord84
09-21-2009 02:28 PM
jcocker03
09-12-2008 01:31 PM
jcocker03
09-12-2008 01:11 PM
doanutboi
11-16-2007 03:29 AM
