how can i increse low end torque
Old 01-14-2008 | 01:14 AM
Jtweaz's Avatar
Default how can i increse low end torque
any suggestions?
Old 01-14-2008 | 10:25 AM
00AccordLX5spd's Avatar
Registered User
Default RE: how can i increse low end torque
use the search function on this site
Old 01-22-2008 | 04:25 AM
YeuEmMaiMai's Avatar
there really isn't tooo much you can do to solve the J30a lack of torque problem. it is a byproduct of the following
1. small intake valves
2. only 1 intake valve opens when vtec is not engaged
edit there are things you can do but that involves doing things like changing out crank, pistons and heads.....and that ain't cheap
Old 01-22-2008 | 10:22 AM
falkore24's Avatar
Just a minor correction. Both intake valves open in low-VTEC mode, but one opens just slightly to prevent pooling of fuel and to enhance the swirl effect in the cylinder. As far as the power goes, it might as well be closed.
Old 01-22-2008 | 07:26 PM
I'm just simplifying the discussion that's all asI am well aware that the second valve opens just enough to prevent fuel pooling at the valve.....but for the purposes of engine performance it is just one valve open.
Old 01-23-2008 | 10:48 AM
marbro's Avatar
i still say get a high volume air compressor and direct port it and let it go full blast ^_^
steviebix
11-21-2007 11:52 AM
liam71234
11-05-2007 03:57 PM
HondaAccordNewb
10-18-2007 07:51 AM
6genex
10-09-2007 05:15 PM
len1967
10-03-2006 04:03 PM
