Hydrolock Scare!!!
#22
RE: Hydrolock Scare!!!
Is there anything else that would cause a Limited RPM range? Like a fouled spark plug or distributor cap? Also, the EGR vac hose was just unplugged for some reason, i probably bumped it one time.
#29
ORIGINAL: falkore24
Jim: Thanks for the code info.
ORIGINAL: falkore24
Water in the oil and low oil? Have you checked your cylinder compression to see if you have a blown head gasket?
AxCxCxOxRxD
11-11-2007 04:50 AM
