I found a h23a and lsd 5 speed
Old 05-29-2011 | 04:41 PM
Boogie's Avatar
Default I found a h23a and lsd 5 speed
ok, i found a h23a and a lsd 5 speed with the wiring harness and the ecm for 1600.00 do you guys think thats a good price and if so what would it take to install in a accord that has a 2.3 non vtec with a 5 speed already, what would i have to change or add ? please i really need the help here with this question, thanks
Old 05-31-2011 | 05:29 PM
g22cd5's Avatar
Supper Moderator
Not a bad deal since the trans alone is worth around 600-800bucks. It's a pretty simple swap. I think only your driver side motor mount needs to be changed to a prelude one and everything else is pretty much a direct swap.
Since you say you have a 2.3 already you have a f23 so your OBD2 is the h23 swap a OBD2 engine or OBD1 engine?
Old 06-01-2011 | 01:01 PM
supercd5accord's Avatar
i would put the f trans on the h23a for sure..I'm not a fan of non-turboed h-transmission cars.
Old 06-12-2011 | 01:07 PM
g22cd5's Avatar
Supper Moderator
Why would you not be a fan of a non turbo h series tranny cars? The h series trans has much shorter gears...for putting more power to the ground faster. That’s why allot of guys who want to keep stock F series engine go with a h22 trans. Just the h series trans swap alone will make you faster than the same year and model accord as yours...just b/c is has shorter gears.
In fact most ppl do it the other way around...if turbo H or F series engine they go with F series LONG gears. The all motor guys go with the h22 gears or B series gears with the H2B kit. If your trying to be fast don't play with the F series gears. Only good for gas millage on the HWY
illestwill
04-21-2014 01:18 AM
maverick21383
02-26-2013 09:54 AM
czr
03-15-2012 11:01 AM
s20700134
12-27-2006 07:52 AM
Quick Reply: I found a h23a and lsd 5 speed
