i need your opinions
Old 09-04-2008 | 02:46 PM
patrickz's Avatar
Default RE: i need your opinions
i was looking on the garret website, and they have many different turbos. which one would be best suited for my application?
  #22
Old 09-05-2008 | 10:23 PM
patrickz's Avatar
wow, i fel like a dumbPOOP HEAD because i dont know anything, but how does this turbo look? http://wwwb oostplanet com/gt20.htm
also, if someone has the time, can they write out what other parts i willneed. this would be much appreciated.
thanks
  #23
Old 09-05-2008 | 10:27 PM
yeah that turbo will do it, if you want a cheaper route find a used 16g dsm turbo. as for other parts you will need a manifold obviously, down pipe, waste gate, blow off valve, boost control, injectors, engine management, charge piping..............
i am by no means a knowledgeable turbo guy, those are just what i thought of off the top of my head as almost all my friends are into the whole DSM thing
  #24
Old 09-05-2008 | 10:36 PM
patrickz's Avatar
is a boost control needed if i only plan on running 4 to 6 pounds?
whats the max stock internals can handle?
  #25
Old 09-05-2008 | 10:44 PM
ORIGINAL: patrickz
yes
i wouldnt run more than 10 on stock internals
of course some peoples motto is boost it till it blows then build it
  #26
Old 09-05-2008 | 10:52 PM
patrickz's Avatar
im sorry i keep asking you so many questions, but how much of a gain will 6 pounds give?
  #27
Old 09-05-2008 | 10:54 PM
the standard is about 10hp per 1psi give or take
  #28
Old 09-05-2008 | 10:57 PM
patrickz's Avatar
60 hp sounds pretty good to me. btw, how much power can an automatic transmission take?
  #29
Old 09-05-2008 | 11:03 PM
if you ran a tranny cooler to it, it should be fine, because heat kills transmissions, and the more power would cause more heat
heres a general turbo guide
http://www gen5alive com/forumshowthread.php?t=176
and heres a guys build on a f22b1 with a slushbox tranny running 7psi
http://www.com/forums/showthread.php?t=5963
  #30
Old 09-05-2008 | 11:10 PM
patrickz's Avatar
ill take a look
Quick Reply: i need your opinions
