Idle Vibration
Idle Vibration
Ok, so I have done a lot to the car since I purchased it. My car is a 1997 Accord Lx 2.2 with 209000km on it. I have replaced the front and rear engine mounts and the other two are perfect, i have replaced spark plugs and wires, cleaned the throttle body, checked for vacuum leaks, gotten transmission fluid changed, unplugged the battery to reset the ecu, put in the Lucas Fuel Injector Cleaner a couple times as well as put it on a premium gas diet, and the steering wheel still vibrates quite a bit at idle... I just know this car has the potential not to shake but I can't get it to stop!
