K20 Clutches/Flywheels
So does anyone know if the K24 Flywheel and the K20 Flywheel are the same... i know the clutches are compatable because they are the same trannys but not sure on the flywheels i know that the K20 is a 8 bolt just like the K24 and the cranks are nearly identical (aside from the stroke) but is the clearance and starter points the same
RE: K20 Clutches/Flywheels
lightweight flywheels in honda's are weird... Honda's typically revv pretty quickly as it is, then to subtract some of that weight just makes the tach look like it's on a little trampolene (comparativly speaking...) let us know what you think of it!
ultrarevvin1
01-11-2014 06:49 PM
ozofjakes
01-05-2013 10:58 AM
