lifter noise at idle. worry?
Old 02-04-2008 | 03:40 PM
Default RE: lifter noise at idle. worry?
The lifters are adjustable, that's what you do to adjust the valve clearance. If it's only clicking occasionally, it might be something else. Each valve opens every 6.6 seconds at idle.
Still, why not check your valve clearance. Then you won't have to guess & wonder about that.
Not only the valve noise, but the injectors seem to click louder than some other cars too.
Old 02-04-2008 | 09:14 PM
Tony1M's Avatar
On the other end of the noise spectrum is the 6-cyl,GL1800 Honda Goldwing motorcycle. That is one quiet engine, and it isn't even under an insulated hood.
ghostynoises
01-05-2017 06:36 PM
leumas01
11-03-2011 10:28 PM
onempty
11-09-2008 04:43 PM
rtmobile96
04-10-2008 01:43 PM
HondaRacer4Vtec
12-06-2006 04:11 AM
