low end tourqe
Old 02-23-2009 | 03:39 PM
finch13's Avatar
Yeah that diesel was supposed to be on some 09 Accord's, but it never happened.
Old 02-23-2009 | 05:14 PM
t00fatt's Avatar
Originally Posted by finch13
Torque? Honda? I don't think those two words can be put in the same sentence together.
What?? My K24 is torquey as *****!!.... For an i4 that is lol
Old 02-23-2009 | 08:26 PM
baconsum1's Avatar
if i have a test pipe will get pulled over out here.. i think i roll with the header and then sway bars and then i might start messing with the throttle body
Old 02-24-2009 | 12:10 AM
clutch811's Avatar
its technically illegal in all states i believe but not all check. watch basically for e-check and such. i dont recommend it instead they do make high flow cats which apparently give similar results. not much gain to be had anyway. sounds like a plan though. good luck!
Old 02-24-2009 | 12:52 PM
jcocker03's Avatar
yeah im pretty sure the test pipe is illegal in all states, but if you live somewhere like WI where they don't emission test you only get pulled over for exhaust if its "louder than normal". As long as your not stupid enough to tell the cop you have a test pipe instead of a cat your good to go over here.
and test pipes are cheaper than high flow cats
Old 02-24-2009 | 02:04 PM
baconsum1's Avatar
na im from CT and we got emissions and sound patrol so im gonna stay waway from a test pipe. thanks for the input. i'll post new pics when im kited up so u guys can see what your building
chrw
01-26-2011 07:12 PM
steviebix
11-21-2007 11:52 AM
liam71234
11-05-2007 03:57 PM
HondaAccordNewb
10-18-2007 07:51 AM
6genex
10-09-2007 05:15 PM
