MID GRADE GAS
Old 09-30-2008, 03:34 PM
finch13's Avatar
Default RE: MID GRADE GAS
ORIGINAL: falkore24
ORIGINAL: smaglik
waste of $.
When my engine is putting out twice the power that it came with and DOESN'T knock, I'll accept the extra $1-2 at the pump.
I certainly hope you would be running high octane gas in a FI engine...
Old 10-08-2008, 05:06 PM
spirited holly
I noticed bad gas. So use gas with invinci clean. High grade gas cost more but help keep her younger
Old 10-09-2008, 02:15 AM
j_tuneberg
no harm will come but if you want to do your car some good get a bottle of seafome and put a 3 of the bottle in the oil a and the rest in the tank it cleans anything that gas runs through and when it is put in oil it cleans ports, lifters, and cams i use it and i have an 82 accord mint with 237,000 +
Old 10-09-2008, 10:00 AM
finch13's Avatar
ORIGINAL: spirited holly
Not exactly correct. The only difference in grades of gas is the amount of octane. Gas either has 87%, 89%, 91% or 93% octane. The higher the octane, the more resilient the fuel is to spontaneous combustion (aka detonation/knocking/pinging). This is why diesel engines don't need spark plugs. Diesel fuel will spontaneously combust at high pressures.
High grade gas is only for high compression engines.
accord04
11-07-2012 11:37 AM
crewzinforabrewzin
08-31-2012 03:21 AM
sajithkaimal
03-05-2010 11:38 AM
Johnene
08-28-2009 09:54 AM
Blacksahara
07-20-2009 11:54 AM
Quick Reply: MID GRADE GAS
