MoonRoof
MoonRoof
I have honda accord 2011 model. It's moon roof isn't working
By pressing the moonroof switch the negative voltages are passing to motor connector's end.
Switch panel passing negative voltages when press open or close switch.
At the motor end there's Direct Positive and Negative voltages are comming and over pressing the switch to open or close the negative voltages are coming.
But still moonroof motor isn't working.
(20A Fuse is ok).
(20A Fuse is ok).
