Is my mechanic liable??
Old 12-21-2011 | 09:15 AM
Gjerde456's Avatar
Default Is my mechanic liable??
Hi All, I'm new to this site and have a relly long question. I recently did the head on my 2002 Honda Accord Ex 2.4L cylinder. Almost immediately it started burning oil like a quart or more every 125 miles or so. I stopped driving it until I saved up enough money to do the piston rings and bearings , which I just had done. When I picked it up the owner of the shop told me it needed new wires , cap and rotor so thats what I was going to do until I took it to my friends shop and he did a leak down test and told me that 1,2 and 4 cylinders all have 175 lbs and cylinder 3 only has 120. They told me to take it back to the shop where the rings were done.
Is it possible they did something wrong, or can they even fix it again?
Thanks !!!!
Old 12-21-2011 | 09:25 AM
Something was not done correctly in the overhaul. Compression is out of spec. They will likely ask you to drive for a while and see if condition improves. I would only do so w/ understanding (in writing) they will correct the problem when it does not resolve (compressions near others).
Old 12-21-2011 | 06:17 PM
Gjerde456's Avatar
Thanks
Old 12-23-2011 | 10:29 AM
maachan513's Avatar
If the leak is occurring through the new rings, it may need some time to be seated properly. Drive around till 500 miles or so and do another compression test. See what kinds of readings you'll get.
Jeff247
09-02-2012 07:44 PM
hopkinted
01-02-2007 05:11 PM
sir_nasty
11-20-2006 09:06 PM
Yangster
08-31-2006 02:39 AM
east302
07-03-2006 02:11 PM
