New To Everything Asking some questions
RE: New To Everything Asking some questions
New Honda Plug wires or the ones i have now?, Cause i don't know about what dealers to go to cause my father gave me the keys.
as too tempurature this is new york city so it's very fickle winter hasn't been what they used to be in the 90's it use to drop -15, but now it like 10 the lowest windchill of -25 .
Is there any part number for the Fuel filters cause i don't know them so i can put them in my list. And when i change the filters do i have to do quickly cause of the fuel leaking or anything like that?
Thanks
Thanks
Hey I finished some more reasearch and i think i made a definte list.
BTW Does anybody have experience on the BG Services?
Here's My list
Spark Plugs - NGK BPR5EY-11
Oil Filter - K&N HP-1004
Air Filter - K&N E-9030
Fuel Filter - K&N 810261? 5/16? *not sure on this part #
Fuel Filter #2 - Mr. Gasket 9768? Not sure on this part #
Cap & Rotor Kit - Accel 8320
Engine oil - 5W-30 SF grade only
Transmission fluid - Dexron II ATF - don't know what brand
Coolant - ???
Thanks again.
Here's My list
Coolant - ???
Thanks again.
tranny use dextron III ,, it is newer,, any brands
use Honda factory cap and rotor
coolant , any brands ,,, prestone . etc etc
BG is good stuff, if you can get your hands on BG-44K add it to the fuel tank , make sure tank is at least 3/4 full
I went to autozone and priced everything that i knew.
Spark Plugs - They don't have a NGK they have Nippon Equivalents 1.99/plug
Air Filter - Duralast DA870 7.99 K&N Special Order $60 (ouch too much for me right now)
Fuel Filter #1 - 3.99 OEM
Fuel filter #2 - 7.69 OEM
ATF - Castrol Dexron III 2.89/quart x3
Oil - Castrol GTX 52-30 Gallon 10.76
Gunk - Motor flush - 2.99
Techron - Fuel System Cleaner - 6.99
Gallon - peak coolant 7.99
Jack 40.00
Funnel 3.19
*edit* - I found about the plug wires at a dealer it's too much $50
I don't think i missed anything except the Cap and rotor they asked me if it was internal or external
i was like huh.?
Thanks for the help you guys.
Jack 40.00
Funnel 3.19
i was like huh.?
