New Guy - When to replace timing belt ???
Old 08-04-2005 | 03:18 PM
billy bronco
Default New Guy - When to replace timing belt ???
Looking to buy 1992 Honda Accord EX, with 118K miles - when does the timing belt have to be replaced?
Is there a way to tell if it has been done if no records are available?
This is a 4 cyl if it breaks is the engine cooked?
I have replaced on a Mazda & Maxima, any big deal in doing the Honda, special tools or anything?
I'm going to look at the car on Saturday, what should I be aware of, things to check for?
Thanks so much in advance.
Old 08-07-2005 | 10:27 PM
Default RE: New Guy - When to replace timing belt ???
Engine will break if you dont replace and you were due about 18,000 miles ago.
I would get with it and do it now before you get that problem.
Welcome to the forums
WheelBrokerAng[sm=americanasmiley.gif]
Old 08-08-2005 | 03:25 PM
billy bronco
So are you saying this is an interferance type engine?
How often have you heard of someones belt breaking?
I'm gonna drive it for a year and take my chances, crazy ????
Old 08-09-2005 | 12:20 AM
dinzer's Avatar
Dude, change your timing belt now, otherwise your looking at big bucks?
it's a sound investment to do this job now.
i changed mine at 120, the belt looked okay when it was done, but with belts you never know, the alternative aint pretty, i know this from first hand experience on a prevous vehicle a few years back, timing belt went and cost me my engine.
take the hit, especially if you have done the job yourself before on other cars
Old 08-09-2005 | 12:48 PM
billy bronco
I need a bunch of info:
First I have no owners manual so I need to find a place on what weight oil, how much. Tire presures and all that stuff.
Is there a link on HOW to do timing belt?
Old 08-09-2005 | 09:44 PM
dinzer's Avatar
Billy,
go to pep boys or straus or wherever an invest a few dollars on the haynes manual for this vehicle, thats what i did for my 2000.
sound investment
it has step by step pictures and how to directions. the timing belt section is really well laid out and explained, you have to know what your doing re setting the timimg marks up correctly, if you dont you'll damage the engine.
if your at all unsure take it to a mechanic.
Old 08-10-2005 | 02:08 PM
billy bronco
There has to be a better web site out there on these very popular Honda's where is it?
Old 04-15-2008 | 12:42 AM
caliass's Avatar
Billy,
Most front wheel drive cars are put together the same, I would recomend a repair manual (ebay for the cheap ones) and alot of sweat and grit. A timing belt is cheap to buy but heavy on the elbow grease. Just change it and feel good driving it for at least 60k before doing it again. Your going to have to lay out about $60 for the book and belt and a day or two to get it replaced. just grin and bear it.
Good luck!
Old 04-15-2008 | 02:01 PM
Tech
Make sure to replace the water pump, cam seal, balancer shaft seal and oil pump o-ring while you're in there. It'd also be a good time to adjust the valves. I just did it the other day. Crank seals almost never leak and they're hard to install correctly so I just leave them alone.
deserthonda
03-06-2020 12:11 AM
01SilverAccord
09-21-2011 06:46 AM
ramone899
03-08-2008 07:58 PM
rotaxrave
12-16-2007 03:52 PM
Tony1M
04-01-2007 06:42 PM
