Pgm-fi
Old 05-19-2011 | 12:57 AM
madeline.meamber's Avatar
Exclamation Pgm-fi
Does anyone know what this warning light really means? My accord after she's all warmed up and running for a while, every once in a while, that warning light will come on and no one seems to know exactly what is it. I've heard fuel injectors vaccum lines ect...
Old 05-19-2011 | 07:34 AM
g22cd5's Avatar
Supper Moderator
1st off what year and trim accord?
Also what light is coming on CEL? ABS? ????
Old 05-20-2011 | 09:47 AM
Default Pgm-fi
She's a 1987 Honda Accord LXi... It's the PGM-FI light that's coming on...
Old 05-21-2011 | 08:35 AM
g22cd5's Avatar
Supper Moderator
hummm Hope someone else chimes in. I'm not to familiar with that gen accord. Have you tried a google search and see what pops up? Also I know there are some forums out there for your gen accord...IO would try one of thos. I don't think too many of the guys here are really knowable with the older accords like that. Now anything from 90+ I can tell you just about anything you want to know.
Old 05-21-2011 | 12:06 PM
Get the codes. The ECU is under the drivers seat. Sldie it forward, makes more room, then look under the seat from the back. You should see a "plastic" cover, to the right is a panel. Pull from the top, it will open and you'll see an LED bulb.
Turn the key to on/pos II (not started, just on). Then count the blinks. Once you have the codes, it will be easier to find the issue.....I'm usually in General Tech, so if get the codes you can post them up there...again I only come to this part once a week or so.....
Old 05-21-2011 | 12:08 PM
G22-I'm not an expert with the 3rd gens (86-89) but pretty good....send them my way in Gen Tech.
Old 05-22-2011 | 08:42 AM
g22cd5's Avatar
Supper Moderator
I sure will bud
tims87LXI
06-24-2011 09:50 PM
litz
06-24-2011 09:46 PM
HardwareJEJ
07-01-2010 03:55 PM
Queen eiko
01-24-2010 01:09 AM
kriegz99
06-18-2007 08:52 AM
