Plug boots melted
Plug boots melted
Hey y'all, I'm new here. My wife has a 1998 LX sedan with the 2.3l VTEC. This past weekend the heater hose blew while driving on the interstate, and the engine overheated as a result. My dad thinks it should be okay as far as the head gasket goes, as I pulled over and shut off the vehicle just a few minutes after the engine started sputtering. I decided to replace the plugs, wires, cap, and rotor. I struggled to pull the wires off the plugs, and once removed I discovered why: the plug boots and parts of the plastic insulators were melted in the plug wells as a result of the engine overheating. I've got one out and most of another, but two are still in there. I've tried everything I can think of: long needlenose pliers, wire, putting a deck screw in the remains and pulling it out - which only worked for one. Any other ideas? I need to get it fixed ASAP. Thanks in advance.
I would cut the wires as short as possible to minimize interference.
Suggest try to grab w/ needle nose vise grips to allow hard pull.
If the part pulls into leaving a ring of rubber in place, suggest using a heated long knife to melt/cut through the remaining plastic. A sharp kitchen knife should work, but will need to be thin and not very wide. Heat w/ propane torch.
If all else fails it may be possible to remove valve cover and remove the spark plug tubes. I googled "honda spark plug tube removal" and found some pics. I don't know they are removable, hopefully someone does. I would suspect the tubes are tightly threaded in place. A special tool is apparently used for Chrysler and Toyota heads, maybe will work for Honda.
I found following video of pulling spark plug tubes and reinstalling. Doesn't say what engine is pictured.
Following video may be helpful.
You need a Factory Service Manual. Suggest an e-manual from automanualsource.com for $22.
There is no access from spark plug tube to underneath valve cover.
I was unable to find any documented instance of someone removing a Honda engine spark plug tube. It may require a machine shop tool to pull outwards w/ lots of force. Apparently, it is relatively easy in Dodge, Ford, and Toyotas.
Got it fixed. I used a flathead screwdriver and a rubber mallet to chip and dig at the remains of the boots until there was enough to grab with the needlenose pliers and pull out. Once that was done I blew out the rest of it with a ShopVac. Car's back in business and runs great. Thanks for the help!
faosh
08-06-2007 08:40 PM
