Radiator Replacement
What would the cost of this be?
Went outside to check fluids and noticed my coolant was low and that there was quite a bit of it on the engine and valve cover. It is leaking from the very top of the radiator where it meets the plastic cover.
So when I replace this, will all of the coolant drain out?
Any radiator you guys recommend? I had a couple people tell me to get it off radiatorbarn.com They have 2 versions:
Your Vehicle1997 HONDA ACCORDSubmodel:ALL MODELSEngine Size:2.2LA/C:FOR BOTH A/C AND NON A/C VEHICLES
The following radiator(s) were found for your vehicle:
(scroll down for additional options)
OPTION 1:
ALL METAL (BRASS TANK/COPPER CORE) CONSTRUCTION; 4 CYL
Specifications Core Size: 13-3/4 X 26-3/4 X 11/16 Inlet Header: 27-3/16 X 1-3/16 Outlet Header: 27-3/16 X 1-9/16 Inlet Connection: 1-1/4 CENTER Outlet Connection: 1-1/4 PASSENGERS SIDE CURVED UP Transmission Oil Cooler: YES Engine Oil Cooler: NONE Mounting: TOP/BOTTOM PIN Notes: ONE ROW, ALL METAL $144.28 1997 HONDA ACCORD radiator $0.00 FREE Shipping in the Continental United States $0.00 FREE Lifetime Warranty -$5.00 Online Discount $139.28 IS YOUR FINAL COST
Please note that sales tax will be added if you live in FL, GA, SC, NC, AL, TX or NV. CSF 2568 OPTION 2:
4 CYL; OE STYLE PLASTIC/ALUMINUM CONSTRUCTION
Specifications Core Size: 13-3/4 X 26-3/4 X 11/16 Inlet Header: 27-3/16 X 1-3/16 Outlet Header: 27-3/16 X 1-9/16 Inlet Connection: 1-1/4 CENTER Outlet Connection: 1-1/4 PASSENGERS SIDE CURVED UP Transmission Oil Cooler: YES Engine Oil Cooler: NONE Mounting: TOP/BOTTOM PIN Notes: ONE ROW, PLASTIC TANKS/ALUMINUM CORE CONSTRUCTION $79.96 1997 HONDA ACCORD radiator $0.00 FREE Shipping in the Continental United States $0.00 FREE Lifetime Warranty -$5.00 Online Discount $74.96 IS YOUR FINAL COST
OPTION 1:
You drain the coolant from a valve at the bottom of the radiator as chris said.
You may have to take the fans off..............either way its not difficult............or if you just unplug them they will probably come out with the radiator.
