Replacing timing belt, waterpump, tensioner, ect. Do brands matter?
I found this OEM kit on ebay, and it looked like it included everything but the tensioners.
http://cgi.ebay.com/ebaymotors/HONDA...QQcmdZViewItem
Is it worth it to buy the OEM tensioners AND that kit, since they are Honda brand? Or should I just buy the Honda timing belt and a Bando brand kit for the rest? Or should I JUST buy a Bando Brand kit for everything?
Here's the Bando. Are they good enough? I read somewhere that they make Toyota's "OEM" belts.
http://cgi.ebay.com/ebaymotors/Timin...QQcmdZViewItem
Thank you. I'm so sonfused. [sm=dontgetit.gif]
RE: Replacing timing belt, waterpump, tensioner, ect. Do brands matter?
Since those parts are so critical....I wouldn't put anything on there except Honda OEM. If I were you, I would buy everything from www.hondaautomotiveparts.com - they seem to be the cheapest Honda OEM parts I have ever been able to find.
Waterpump, tensioners, and timing belt - Honda OEM
Drive belts - whatever you want - you can replace these with little effort and they are not catastrophic to the engine if they break.
I bought a Gates timing belt kit. Gates isa good belt manufacturer and they commonly used in the hot rod/street rod/customs scene. If you're unsure about brands, Honda Genuine is your best bet.
mark95
01-22-2015 10:34 PM
