seriously? the O2 sensor?
Old 07-09-2008 | 11:45 PM
ford's Avatar
Default RE: seriously? the O2 sensor?
ORIGINAL: status
the idiot at the dealer the service rep tried to tell me that the engine light might have come on instead of maint light...
lol!! yeah that is retarded...but yeah...check your o2 sensor wires...
Old 07-10-2008 | 08:48 AM
KevinAccord's Avatar
just to add an idea, check if they are pluged in all the way. It's not hard to change them, not too long ago I changed 3 sensors (one oil and 2 air) from a friends altima. took me 30 min
Old 07-18-2008 | 01:49 PM
status's Avatar
so it finally came back on today. had it checked. and the dude said either LEAN 1 or LEAN BANK 1. and its the front o2 sensor. but he said the computer they have arent as good as the ones they have at the machanics. so if any one knows what that means.
Old 07-18-2008 | 02:29 PM
klrspz's Avatar
means he's full of crap and made something up... take it to a real shop or just replace the O2 sensor (not actually suggested, but if you already spent $65+ at one shop, it might be cheaper just to replace it than get it tested again to find it's actually bad)
Old 07-18-2008 | 03:19 PM
ORIGINAL: JimBlake
Go back & have someone read the code again. Tell us the ACTUAL CODE NUMBER. That will say which sensor and we can give you some things to measure or check.
The ACTUAL CODE NUMBER will begin with the letter P & then it has 4 digits.
Old 07-18-2008 | 03:30 PM
onehung2low's Avatar
reset your ecu man and the light will go off
  #17
Old 07-18-2008 | 04:23 PM
ORIGINAL: onehung2low
Only if you fix what caused it.
  #18
Old 07-18-2008 | 05:01 PM
if its the pre cat o2 sensor then all you have to do is reset the ecu and it will go off, the one actually on the cat is a diffrerent story
  #19
Old 07-18-2008 | 05:12 PM
ORIGINAL: status
got my check engine light on read at knects and the said it was the O2 sensor. my car only has 44k on it can this be? and how much to replace? i only have a powertrain warrenty and i assumed it was under that but the dude at the dealer said its part of the emissions. and it would cost 250 for the front one or if it was the back it would be 350.
|Buy the sensors at AutoZone $ 69.00 each and rent the O2Sensor tools for free..You dealer is a As$Wipe..
Old 07-18-2008 | 07:54 PM
status's Avatar
auto-zone lets you rent the tools?
Quick Reply: seriously? the O2 sensor?
