Sohc or Dohc?
RE: Sohc or Dohc?
each side of the v6 engine has one over head cam which makes i a sohc, but, since there's two, legionofone refers to it as technically dohc which is not incorrect, he'sjust adding both over head cams, which i guess that was what he meant. but if you are gonna put a decal it should say sohc.....hope it helped!
RE: Sohc or Dohc?
I don't know if anyone else has noticed this or not but Accord plug wires are spendy..... I've found that it's only like $10-$50 more (depending on what set you're looking at) to get a good set of Nology wires....
kangas
03-21-2008 03:29 AM
