Spontaneous Shut Down
My 1992 Honda Accord, 239109 miles, had been shutting down while running latly. It would be going smoothy, then cut out with a shake, resume then about thirty seconds latter it would compleatly die. After coming to a stop it would take two or three tries to start it then it would run again. This problem dissaperaed for about a month, then it compleatly went down. it hardly starts and when it does you can hear it missing and dies unless you hold rpms boarder red line. Any Ideas what could be wrong?
Is Check Engine Light ever on? If yes, see DIY section for code extraction.
Maintenance up to date? If not, new plugs and perhaps wires. Check wires w/ water spray at night. Any sparks mean new wires needed.
CTSilver00Accord
06-06-2013 12:55 PM
mstwntd16
05-08-2012 10:09 PM
