tapity-tapity-tap
Old 10-09-2007 | 06:49 PM
thaxman's Avatar
Default tapity-tapity-tap
OK, so now I have a tap appearing at idle. I assume its valve related, but w/an OHC, its not a rocker arm. My CRX had a whole valve cover full of knocks at idle - this sounds like 1 valve. Is this common & should I get it taken care of ASAP?
Old 10-09-2007 | 10:49 PM
Default RE: tapity-tapity-tap
The valve tappets are just like rocker arms. There's an adjustment screw at one end. On SOHC Accords the valve lash is measured at the valve stem, not at the camshaft lobe. Check & adjust when cold. Lash should be printed on a sticker under the hood.
Old 10-10-2007 | 03:57 PM
falkore24's Avatar
I'd give this a shot:
1) engine flush
2) Marvel Mystery Oil
3) after 3000 mi, engine flush at normal idle for 5 minutes
accord05thirteen
01-09-2015 01:10 PM
accord05thirteen
11-19-2014 02:29 PM
Davidwhittle76
04-12-2012 12:18 PM
dave1977nj
02-28-2011 11:41 AM
MakoMan
06-28-2007 08:44 AM
