timing belt
Old 11-29-2008 | 01:14 PM
srpowersuw's Avatar
Default timing belt
My car has about 74K miles. When does the timing belt need to be changed? How much does that usually cost?
Old 11-29-2008 | 01:24 PM
Default RE: timing belt
You may want to look into if your car has a chain or a belt, I know the 03 4cyl has a chain, which a chain needs to be replaced far less often.
I forgot when Honda recommends the belt to be done, its somewhere between 80-100k.
Old 11-29-2008 | 01:30 PM
botang47's Avatar
honda told me to do it at 100k but i didnt do it till 120k and it was working fine still. i just did it cause i was already changing my rotors, pads, water pump, and spark plugs already.
Old 11-29-2008 | 08:44 PM
skatingclaybird's Avatar
it cost me the whole timing belt and water pump tune up about 100 dollars
Old 12-01-2008 | 10:41 AM
falkore24's Avatar
SRSpower: I-m not 100%, but I think the interval is 105,000 miles on the timing belt. Unless you are doing the work yourself or with friends that are helping you for free, this job will cost between 500-800 dollars.
john_pyro
08-04-2019 06:06 PM
5.0stang
04-23-2013 07:37 PM
ss485
02-23-2011 09:18 PM
Jay 3rd
02-17-2008 11:54 PM
Tony1M
04-01-2007 06:42 PM
