Which transmission fits my f22a1?
Old 03-28-2008 | 01:17 AM
pwcracker2002
Default Which transmission fits my f22a1?
I am having my transmission replaced in my 92 honda accord lx but i am unsure about which transmissions fit in it. Will a transmission from a 95 accord fit in it because i found one at the salvage yard with only 90k miles on it which is much better than my 293k? its an auto tranny btw. if anyone could help me about it would be great cause i need this info asap. thanx
*edit*
after doing a little more research it seems that any f22 will swap with each other and also the h22, is this correct? i believe the tranny im looking at is from an f22b2 so i think it should work.
Old 03-28-2008 | 09:59 AM
falkore24's Avatar
Default RE: Which transmission fits my f22a1?
sounds like you're on the money! I know that for MT, the H22 tranny has a closer gear ratio, meaning better acceleration for a bit worse mpg. I'd expect the autos to follow the same pattern.
doop
08-24-2009 01:03 AM
Vialas
03-20-2008 09:40 AM
muskokatennis
02-24-2008 07:54 PM
rhrhkdals
07-25-2007 10:11 PM
codelogic
10-30-2006 04:22 AM
