The two-stroke engine is simple in construction
Old 01-06-2010 | 11:08 PM
tuti123's Avatar
Banned
Default The two-stroke engine is simple in construction
The two-stroke engine is simple in construction, but complex dynamics are employed in its operation. There are several features unique to a two-stroke engine. First, there is a reed valve between the air-fuel intake and the crankcase. Air-fuel mixture enters the crankcase and is trapped there by the one-way reed valve. Next, the cylinder has no valves as in a conventional four stroke engine. Intake and exhaust are accomplished by means of ports - special holes cut into the cylinder wall which allow fuel-air mixture to enter from the crankcase, and exhaust to exit the engine. These ports are uncovered when the piston is in the down position
diesel parts
import car europe
Old 01-07-2010 | 08:17 AM
Yeah, thanks for your tremendous insight. But we DO NOT LIKE SPAM.
hawaiian5
02-27-2012 06:38 PM
Calgary Rob
06-25-2010 01:20 AM
AccordLXMaster
01-23-2009 06:57 AM
badxdawgx818
06-12-2007 06:47 PM
kenneyd
06-01-2007 11:01 PM
Quick Reply: The two-stroke engine is simple in construction
