"Buzzing" sound (ABS?)
Old 03-07-2007 | 05:11 AM
tiger94's Avatar
Default "Buzzing" sound (ABS?)
Hi Guys and Gals,
I have a 2000 Honda Accord SE, and it has about 60K miles on it now.
Starting a couple of months ago, I have been noticinga "buzzing" sound.
This sound lasts about a second, and seems to originate from the left(driver's) side.
It happens a couple of seconds after I put the gear into "D" and start driving.
From what I've searched in the forum, it seems as though it is related with the ABS system.
(Found on this forum ---> My 97 Accord has been making the "buzzing" sound for many months, maybe years. I now know that it has most likely been the ABS pump re-pressurizing the ABS system.)
Is there any way that I can get this noise to go away (without taking it into the shop and spending money!!!)
Thanks in advance!
Old 03-07-2007 | 05:55 AM
deserthonda's Avatar
Default RE: "Buzzing" sound (ABS?)
well first of all you need to figure out what the noise is exactly...
does noise only happen as you drive away ? or when car id put in gear and ready to drive away ?
can you duplicate the noise if a person puts the car in gear and foot on the brake+ e-brake
and you can listen with hood open to try to pinpoint its location ? ?? it could be the abs motor ..but
buzzing sound could also be coming from exhaust manifold heat shield ??
Old 03-07-2007 | 06:00 AM
tiger94's Avatar
>>>>Yes, only when I drive away. Just once, right after the ignition is turned on, and as I drive away on "D".
Old 03-07-2007 | 03:32 PM
Don't take too much into that statement about the '97 Accord. Beginning in '98 the ABS system no longer has a hydraulic accumulator that needs to pump itself up when you start.
Fuzzeroni
06-15-2015 07:15 PM
andy 95
07-16-2011 02:48 AM
joepeterson56
03-15-2008 09:48 PM
ndorfin
08-21-2007 05:17 PM
ernie22golf
10-18-2006 02:35 AM
