**2001 coupe ex remote start problem**
Old 11-12-2011 | 05:07 AM
RT1018's Avatar
Default **2001 coupe ex remote start problem**
Okay, so I just bought a used '01 silver coupe ex and i love it!. It comes with an AutoMate AM6 already installed but apparently never used. When I hit the button on the remote to start it, the engine cranks but won't turnover. It repeats this three times, and then stops. When I start the car normally, it starts right up. When I have the key in the ignition turned to the "acc" position, it cranks 3 times then repeats just like when the key is out of the car, but when the key is turned to the "on" position but not started, and i hit the remote start button on the key, it starts right up. I have no idea why it does this and I want to be able to use this feature when its 30 degrees out and there's tons of snow on the ground. Please help !
Thanks HAF !
Old 11-12-2011 | 09:25 AM
It was mis-wired initially and will need to be re-worked. You will need to contact the remote starter manufacturer and obtain an installation manual. Then you can find what has been wired incorrectly.
Old 12-08-2011 | 02:21 PM
k24acura's Avatar
The imobelizer is not allowing the car to be started. 1 the box that they put the key in was removed or they didn't put one in and it never worked before.
Desert Boomer
01-04-2015 04:28 PM
ardvaark65
02-06-2009 09:27 PM
01AccordCoupe
12-12-2007 06:57 PM
tradosaurus
08-15-2007 09:07 AM
dave74
01-06-2006 11:21 PM
