00' v6 LX dies on startup every so often help.
Old 06-03-2012 | 05:17 PM
HashGobbler420's Avatar
Default 00' v6 LX dies on startup every so often help pleae.
Hey, so i have a 2000 accord 3.0 v6 its been amazing to me for the last year but it has always had a reoccuring issue. It seems to be after i drive the car for semi long time or distance like 15-20 miles at least. So it drives good but ill drive for a little while then turn it off and when i go to turn it back on about 5-10 minutes later it starts right up but the rpms dont hold and the car shuts off. if i give it gas it will stay on but die after i let off. (it spudders a bit)But if i hold them at 2,000 for at least 1 or 2 minutes it will stay on reluctantly.
I went to advance the ran my codes it had a valve clearance issue egr valve and a miss fire. i had the egr taken off and cleaned thoroughly replaced the spark plugs and some people said it was the battery so i bought a 660cca expensive as **** battery. (for future system) and it kindof seems to be running worse im getting a prety good delay in time from hitting the gas untill pickup. i plan on taking it to the local honda dealer but its $120 just to read the codes so i kinda wanted to get a little advice. my friend at tire kingdom said it could be the cap or router on distributer or mass airflow sensor. anyways all help is appriciated.
Old 06-04-2012 | 06:57 PM
Are the codes still there?
Old 06-07-2012 | 03:10 PM
figured this issue out today at the shop $70 fix thanks for the help guys...
Old 06-08-2012 | 08:00 PM
...ok, can you at least tell us what it was.
jacksprat
09-07-2012 05:55 PM
bobrae2011
08-05-2012 10:35 AM
Nicolai Hobbs
07-12-2012 06:44 PM
deserthonda
05-21-2006 06:24 AM
Hondamatic
05-01-2006 05:28 PM
Quick Reply: 00' v6 LX dies on startup every so often help.
