01 accord coupe ecu help... please
After work today I’m going to check ecu grounds, g101 I think, at the intake manifold. Also I plan on pulling the main relay and bench testing it, as well as it’s plug, but having trouble finding a pin out for the main relay specific to my car, any help would be very appreciated with that.
You've changed the PCM so here's a strange possibility. I recall this being the solution for someone here quite a while ago. No guarantees, but you should be able to check it.
After unplugging and reinstalling the wiring harness plugs onto the PCM, this person had strange problems. After going crazy checking everything, they finally found that one of the pins or sockets inside a wiring-harness plug on the PCM had retracted from the large plastic plug-thing. In fact, you can remove individual wires from that plug by releasing a little barb that holds the wire & socket in place. This socket had pushed back to the point where it wasn't making contact with the corresponding pin on the PCM.
#17
I just got off work, and checking more things now. Thank you everyone for your insight and help. The ignition coil is inside of the distributor to witch a new one has been installed, along with crank pos and all associated parts.
#18
The numbers on my main relay are different from the diagram, same number of pins, just numbered different. When I checked it according to the link, it failed the first test, but again, not sure I’m hooking up to the correct pins.
