01 Accord Power Steering Problem
Originally Posted by JimBlake
To me, a squealing noise sounds like a slipping belt. Can you have someone start the engine while you watch to confirm the PS pump pulley is turning properly? Then do the first couple turns in an empty parking lot somewhere, then confirm that the squealing sound is actually coming from the drive belt?
on a few occasions, I’ve felt what seems like a jerking motion in the steering wheel. Not often but a couple of times for sure.
We have to rule out the simple stuff first. Can you verify the pump pulley is spinning properly when you first start up? I'd hate to suggest you replace the pump & then find out it was something as easy a loose or bad belt.
