01 accord V6 sedan keeps draining the battery after changing alternator
Old 03-29-2012 | 04:20 PM
01SilverAccord's Avatar
Originally Posted by PAhonda
What brand of alternator did you install in your accord?
It's Worldwide Alternator - 105 Amps at Advance auto parts.
The battery died again and the parasitic test didn't show any amp drawing..
Old 04-12-2012 | 08:12 PM
Does anyone know what this part call?
it's right after power steering reservoir. I accidentally hit it and the cable was throttle cable was loosen and the car wouldn't start. I tried to push the cable back inside but I could only push it back a little like in the pic
Since then, the car idles fine but when I give it a little gas, all the rpm needle, gas needle, and temperature needle dropped like the car is shutting down.
Is the part in the pic changable? or can I open it up? I was tempted to do that but just want to ask for advice first. Thanks
Old 04-12-2012 | 08:39 PM
It the cruise control actuator. See attached image. The parts can be changed, etc.
Attached Thumbnails 01 accord V6 sedan keeps draining the battery after changing alternator-cruise-control-actuator.jpg
Old 04-12-2012 | 08:41 PM
thanks for the info.. I'll check that out..
Old 04-15-2012 | 09:07 PM
I check the wire from the alternator to the fuse box and it's corroded so bad to the point I don't think it has any connection.
I'm trying to replace the terminal ring but the wire itself is gone. Does anyone know if i can order it online? I don't want to go to stealership and pay $50 for that wire.
Old 04-16-2012 | 06:17 PM
Might check the prices online and see what the wire/cable goes for.
If not, in my day, you can look around for local places that can/will make cables. When I use to sell parts for a living, we had/sold pre-made cables but at the same time we were set up to make custom cables.
  #17
Old 04-18-2012 | 09:07 PM
I've checked online store and it seemed nobody carry that cable and I've been driving around, parts store told me go to the dealership. Sighhh....
  #18
Old 04-18-2012 | 09:46 PM
I would try to find the oem part number for that wire. There are sites like hondapartsnow.com that give oem numbers.
You may want to call the dealership to find out what they charge for one.
R0CKY
12-06-2010 08:59 AM
MyBrotha92LX
10-02-2009 07:12 AM
MyBrotha92LX
10-02-2009 06:33 AM
driver6198
01-02-2009 11:19 PM
Quick Reply: 01 accord V6 sedan keeps draining the battery after changing alternator
