01 Ex Starter problem
Old 06-05-2008 | 01:51 PM
remnam
Default 01 Ex Starter problem
I have a 2001 Accord EX 2 dr coupe, 5 sp manual transmission, 4 cyl.
I am having trouble with starting. I get a click and then nothing when turning key. Most times, iwhen I try a second time, car will start. Sometimes it takes 3, 4 or 5 triies. Have just replaced battery with new one, so have ruled out battery. Terminals and connections are all clean and good.
Believe the problem may be in Neutral Safety Switch? But not sure how to check this. 7 year old car has had some other minor electrical bugs that I have fixed (micro-switch in seat belt!) and am hoping this one is similar.
Help appreciated
Old 06-06-2008 | 11:14 AM
Default RE: 01 Ex Starter problem
Only automatics havea neutral-safety switch. Yours has a clutch switch instead. If that's broken (or if the clutch pedal isn't pressed down), the starter won't even 'click'. Can you pinpoint the location of the 'click'?
Old 06-06-2008 | 11:22 AM
Hit the starter while trying to start it. If that works, get a new starter. Or fix yours with new contacts.
Donda
08-20-2010 01:40 AM
trukid21
01-23-2009 10:31 PM
R1ckyB0bbyyy
09-08-2008 02:48 AM
gpsodave
08-29-2007 03:34 PM
fmeier
07-22-2006 03:14 PM
