01 LX Blower Fan Noise
Old 02-09-2008 | 03:47 PM
accordfan's Avatar
Default 01 LX Blower Fan Noise
The blower motor on my 01 LX has started to squeel recently. It will only make the noise for about 15 seconds, and only when it is cold outside/inside the car. On a warm day, no noise.
Question: I'm assuming this is a bearing noise. Can this be eliminated by lubricating the fan bearing in some way??
Thanks!
Old 02-09-2008 | 05:56 PM
sir_nasty's Avatar
Default RE: 01 LX Blower Fan Noise
you could try lubricating it and it may very well help if it is the bearing, worth a shot anyway if you can get to it easily...
Old 02-09-2008 | 06:51 PM
accordfan's Avatar
Is it a sealed bearing??
Old 02-09-2008 | 08:04 PM
mpanelli's Avatar
I believe the motor is a sealed unit with no serviceable parts inside. If it is the bearing or the shaft you could try and put a couple of drops of light oil where the shaft enters the housing. This would probably be a fairly short term fix. Here is a diagram of the blower housing. The motor alone is about $130. Make sure it is the motor and not something else like the fan hitting something. The motors usually last for a long time.
here is a link to a website that shows the exploded view of the blower assy. It has prices as well.
http://slhondaparts.com/browse.asp?M...ViewParts=true
[IMG]local://upfiles/2129/EEAF4FF8FF5D44F29EA4BB9136279F0D.jpg[/IMG]
Old 02-10-2008 | 08:06 AM
accordfan's Avatar
Thank you very much. I appreciate all that information.
Old 02-10-2008 | 08:50 AM
The squealing is the armature rubbing against the permanent magnet field housing. The squealingmeans the bearing (oiled bronze bushing) is worn or the bushing mount is loose. These motors are not repairable. I tried and failed, and certainly not worth the effort.
It won't get better so locate a replacement part and be ready.
Old 02-10-2008 | 10:26 AM
HondatechAV6's Avatar
leaves tend to get in the blower motor causing intermittent noise also. remove the blower motor and inspect it.
Honda Man For Life
04-09-2012 09:38 AM
anothervietguy
12-13-2007 08:52 PM
Calevra18
09-08-2007 09:36 PM
mcp555
07-22-2006 02:00 AM
randomguy1287
07-16-2006 02:49 PM
Quick Reply: 01 LX Blower Fan Noise
