03 Accord strange noise from sepentine belt area
Hi my 2003 Accord lx 4cylinder has now has a strange noise coming from sepentine belt area. I replaced the tensioner pulley but noise still there. I removed the serpentine belt again and noticed that the larger lower idler pulley wobbles (no sure if that's what it"s called). Is that normal. I can't see a screw to remove and replaced if it has a bad bearing. Is it safe to drive?
Thanks
Thanks
You should be able to drain the coolant, remove the belt, then unbolt the water pump. Installation is the reverse.
I am not sure how much room you have to access the bolts for the water pump. I never did this job on a K-series engine.
briggsrepair
09-13-2013 11:17 AM
95Coupe_360
07-19-2013 01:31 AM
barryfaetheus
04-29-2011 06:43 PM
