03 Accord Tune Up
03 Accord Tune Up
With 118000 miles. The car will "hesitate" when accelerating/changing gears. I am thinking it needs a tune up. What are some things that would make the car "hesitate" when changing gears?
If tune up, is this something i can do myself?
What type of plugs and wires should i be using?
Just looked over the carfax again and it does not say anything about a tuneup. It mentions all the manufactuers checkups but nothing on tuneup. When does honda recommend a tuneup?
Ok, so I went to remove a spark plug and just inspect it to see what the plug looks like (dirt, oily etc). It is a 4 cylinder and I think I located the plugs (under a black plastic cover). The problem is, there is a "bar" that goes acroos the plugs secured by 2 nuts. I removed the nuts but was not able to remove that "bar". I didn't want to do any damage so I stopped and came here to see if anyone has changed plugs in a 2003 accord lx? Can you share how to do this?
You got no distributor, & no spark plug wires. I'm guessing that "bar" is the top of the coil. You have one coil for each plug. Un-do the bolts & lift it up - takes about the same amount of force as pulling a plug-wire.
jkp
12-21-2004 11:15 AM
