03 Honda Accord Idle vibration
Old 07-06-2007 | 10:19 AM
wegipip
Default 03 Honda Accord Idle vibration
Hi I have a 2003 Honda Accord fourdoor auto43000miles when the fan speed in on full and the AC is on the steering wheel vibrates alot when I turn the AC off and the fan speed down the vibration is still there but not that bad, I don't know whats going on! Please help.
Old 07-06-2007 | 11:21 AM
smaglik's Avatar
Default RE: 03 Honda Accord Idle vibration
engine mount already?
Old 01-02-2017 | 07:58 AM
djpoint's Avatar
Default vibration on 93 honda accord lx
I am getting all four motor mounts replaced Thursday. The repair shop recommends poly mounts. What i dont understand is that this would eliminate the hydraulic mount in rear. Is that true? Heavy vibration in drive when idling. I know, in know. everyone says that these honda's during those years had a vibration, but not this bad, when the dash and steering wheel shake. Honda wouldnt have sold millions of these models if it did. So are poly mounts good? and no need for hyraulic one anymore?
Old 01-02-2017 | 12:37 PM
Poly mounts are stiffer than OEM and will transmit more vibration. OEM is recommended for best idle vibration.
If idle speed is dropping as load is added (AC, electrical, PS) then idle air control valve may be the problem. Cleean IACV, throttle plate (both sides).
newHondaUser
06-07-2024 10:23 AM
sssexy70
05-29-2024 12:43 AM
214texas
04-10-2022 03:59 PM
dmullen
12-01-2007 12:28 PM
sssexy70
01-27-2007 04:40 PM
