03 Honda Accord Shaking
Hello there! I am in desperate need of help! I have an 03 Honda and I am experiencing shaking/vibration around 48-55mph! I have replaced all the motor mounts, tire's have been replaced, balanced and aligned, changed the axels, new brakes and rowdier's! We also got the oxygen sensor's and spark plugs changed!
NO ONE can seem to tell me what it wrong and want to keep "trying" things at the expense of MY pocketbook! I don't know if it is worth taking to Honda paying them $100 to look at it and tell me what everyone else has told me!
Does your check engine light turn on while driving, or the D4 light flash?
I wonder if your EGR ports need cleaning? The car would stumble or shudder at ~2000 rpm. There are write-ups for the 90-97 4 cylinder accords and the 98-02 accords. I am not sure how to clean the 03+ accords, or if that is even a common problem.
I've heard of vibrations being caused by compliance bushings (large rubber bushings on the front lower control arms). It wouldn't hurt to check them out, to see what they look like. You can see them pretty easy, in front of the front tires, where the control arm attaches to the frame. With all the stuff you replaced to this point, I think I would look closely at suspension parts. Seems they would have checked all that before they did an alignment, but maybe not.
toneslish
06-28-2010 06:53 PM
97LX
06-11-2007 10:03 PM
