03 trunk light
Old 05-30-2007 | 02:38 PM
dmoak's Avatar
Default 03 trunk light
The trunk light in my 03 Accord EX has stopped coming on. I replaced the bulb, but that didn't help. There's no voltage at the light when the trunk is open. I assume the switch is in the trunk latch itself since I can't see a separate switch anywhere. What else can I do to find the problem?
Thanks!
Dave
Old 05-30-2007 | 03:16 PM
sir_nasty's Avatar
Default RE: 03 trunk light
Welcome to the forum! I'd start by checking your fuses since there is no power there, then trace the wires and make sure it didn't get pinched or broken....
Old 05-30-2007 | 04:46 PM
Rhoderman's Avatar
Check the little indicator light in the dash that tells you if the trunk is open. If it works, you can probably assume the trunk switch is okay. If it doesn't work, gut the latch mechanism. I'm believe you're right in thinking the switch is in there.
woody_968
09-05-2018 10:07 PM
bdrumm
10-30-2012 11:46 AM
thaison86
06-28-2012 01:03 AM
MNHONDAGUY
05-08-2007 08:52 PM
MrRochie
06-24-2005 09:28 PM
Quick Reply: 03 trunk light
