0420 code...replacing parts.... still on....
Old 03-18-2008 | 06:35 PM
Prizma's Avatar
Default RE: 0420 code...replacing parts.... still on....
ORIGINAL: JimBlake
It's not only Autozone. What kind of car-parts chains are up there? Canadian Tire? Pep Boys? Advance Auto Parts?
We have Lordco up here that I goto. I get a 30% discount there.
ORIGINAL: JimBlake
You can clear the code yourself. On your 1998 you go to the right-side dashboard fusebox (near door hinges). Pull fuse #13 for 20 seconds or so.
If you clear the code & let it come back, then you erase any old leftovercodes so they don't confuse you.
I'm blonde. I'm always confused... Sweet. I'll do that tonight and see if it comes on again. Is there a technical name for the computer code reader? I don't think they'll understand me if I use hand gestures and call it a thingiemagoo....
  #22
Old 03-18-2008 | 07:19 PM
Simple ones are called "OBD-2 Code Readers". About the size of a large calculator, with a wire that plugs into the OBD-2 port near driver's left knee. That's usually what the parts-store-guy will take to the parking lot & plug into your car.
More expensive & powerful ones can also display data from the car, like injector duty cycle or engine temperature or fuel trim, etc...
understand1
08-28-2012 06:42 PM
jaydev
03-26-2012 10:18 PM
techjohnny
12-27-2011 11:19 PM
jasonalanmorgan
06-10-2010 08:10 PM
Rwydeven
07-15-2007 10:26 PM
