05 Accord V6.....Compressor clutch coil replacement.
Picked up a 05 accord with 87K miles. In good shape mechanically except that it needs the field coil replaced on the compressor. The clutch wont engage and Ive verified that direct 12 volts to it wont engage it. Ive also verified it does have a good ground.
Is there a way to replace the coil without removing the thing from the car itself?
My understanding is you remove the outside 10mm bolt. The plate comes off and there in a shim you gotta be careful of. Then a snap ring which once that is off you can slide the pulley out. Then after those are off the field coil has another snap ring.
Just like in this video. Same compressor and all. Once all put back together you got to make sure the distance between the plate and pulley is 0.014-0.024 inches. I sourced a field coil for $32 shipped online.
Have you checked that clutch gap is not the problem?
If pushing clutch plate w/ screwdriver causes plate to close, gap is excessive and removal of a shim to reduce gap should fix the problem.
You're on the right path.
What I do with them is remove the lower plastic couling, remove the four mounting bolts to the block and there is enough to play in the A/C lines to move the compressor around so you can get the clutch and field coil off without opening the system. You need the tools to do the job. Make sure you have a good set off retainer ring pliers. So to answers your question, yes, I do them on the vehicles.
IMPORTANT NOTE: Contact your Honda dealer first. They extended the warranty to 100k for the field coil on several of their vehicles, but I can remember if yours falls into the category.
Also, first check the field coil by jumping it with 12v from the battery. If it clicks then it is not the field coil but rather something with the clutch as stated above. It may be a shim. If it does not click then it is the field coil which is a rather common problem.
Good luck!
Good luck!
Thanks guys. I can apply 12 direct from the battery and it doesnt pull in. With vehicle on I can tap the clutch and it wont pull in either even though there is 14 volts at the connector and the ground is good.. So my coil is toast.
They are about $40. I appreciate your reply that it can be done on the car. Do I need to remove the alternator a bit more room?
Was able to take care of it this weekend. I used one of the below vise grips to hold the clutch down to remove the bolt.
Then everything came apart just like the diagram above. I did have to unbolt the compressor and work it from the front. Just have some good snap ring pliers and a good 12mm ratcheting box end will help get the top drivers side bolt from the compressor off.
AC works fantastic now.
James Glenn
12-30-2014 09:04 PM
phantomgrey92
10-09-2013 04:45 PM
clutchless
03-08-2011 11:50 AM
