06 accord v6 CEL codes p0172 & p0497 help
Old 02-22-2013 | 02:46 PM
JDS06EX's Avatar
Default 06 accord v6 CEL codes p0172 & p0497 help
So this week the check engine light came on 3xs finally checked out the codes and came up with p0172 & p0497... The research that i have done has lead me to da evap system.. But kinda stuck so was wondering i can get some help.
Old 02-22-2013 | 03:23 PM
Dr. Drivability's Avatar
well, the p0172 is a rear bank rich condition code. more than likely it is being triggered by the p0497 code, which is either the FTP sensor or the EVAP canister vent shut valve <<<this has my vote. in any event, don't worry about the p0172 until you get the p0497 fixed first.
Old 02-22-2013 | 03:30 PM
JDS06EX's Avatar
Thanks for the response.. Are both the ftp sensor and shut valve located with the evAp canister? Anyway of testing those out? Ohms?
Old 02-22-2013 | 03:34 PM
P0172 = system too rich
P0497 = EVAP low purge flow
EVAP purge flow is when the EVAP purge valve opens and the engine draws some air into the intake manifold, through the EVAP canister. Look for obstruction in that line. It sucks through the EVAP line which is a steel line alongside the fuel lines under the car. Is it crushed from a rock kicked up by the tires? Corrosion? For that matter, what about the EVAP purge valve being pluged with corrosion?
System too rich? Maybe try a bottle of Techron or something like that in the fuel tank. Even if it doesn't work you haven't wasted much money.
Old 02-22-2013 | 03:35 PM
no, the fuel tank pressure sensor is in....wait for it....the fuel tank
Old 02-22-2013 | 03:42 PM
my bad...was thinking of another car, it's under the car near or part of the canister assy.
jhanratt
09-01-2014 11:37 AM
Jacob305
04-23-2013 08:09 AM
theacegun
07-16-2012 08:16 PM
Ryan1984
06-21-2012 02:23 PM
goofy_addict
05-31-2007 04:52 PM
