06 Accord -where to put jack stands
I know where the reinforcds areas are to jack the vehicle up but once the car is up where do I put the jack safety stands. I couldn't find the details on the net. Need to change rear brakes and fix an exhaust leak.
Not sure about 2016 specifically, but Honda has traditionally put a lifting pad in the center front & rear. I use that to jack it up, then put the jackstands under the rocker panels at the points that are reinforced for the tire-changing jack.
This is from the 6th-gen shop manual, but all the others I've known were the same (1992,1998,2003 Accords; 1995 Integra; 2000,2007,2013 Civics). The front point is a flattened spot on the crossmember almost underneath the radiator.
letsclique
12-28-2012 05:39 PM
