07 Accord, Canopy LIght Lens Removal
Old 10-29-2011 | 08:38 PM
Default 07 Accord, Canopy LIght Lens Removal
Canopy Light is out and needs replacement. Shop manual says pry at lens end to release. I pried as much as I dared w/ no release.
I could use a wood block fulcrum to gain more leverage, however I'm concerned about damaging the lens.
Anyone released this lens and have any suggestions or tips?
thanks
Old 10-29-2011 | 08:52 PM
For the canopy lenses, are you referring to the spot lights/map lights or the dome light? Some of the plastic lenses have tabs, so knowing where the tabs are located helps to make it easier to pry out. Normally, it is recommended to also use a shop towel while prying to prevent scratching.
Old 10-29-2011 | 09:03 PM
This thread includes an image of the locations of the retaining tabs on the spot/map light lenses for the 7th gen Accord:
https://www.hondaaccordforum.com/for...30/#post256228
Old 10-30-2011 | 01:37 PM
Thanks for response. The overhead, central dome light is the one I need to replace. I will try again w/ a rag as indicated. It's alarming when it deflects 1/2" w/o release.
thanks
Old 10-30-2011 | 04:57 PM
I took another fresh look and embarringly, I was prying on the base fixture instead of the lens. You have to look close to see the lens is separate.
Bulb replaced and all is well.
thanks
gboone
10-23-2011 06:10 PM
Dono2004
03-13-2010 09:55 PM
clothesline
01-23-2010 04:06 PM
2kflhr
06-24-2007 07:14 PM
