07 Engine blown - 4 cyl EX-L 5sp manual
Today my Accord died. It ran beautiful this AM starting the trip but 3 hours later it was almost dead. I noticed lack of power, and when I slowed down for the first time at a stop light, it would hardly run. The codes showed missing on cylinders 2 and 3 and catalytic converter issues. A mechanic checked the plugs, wires, coils, and finally a compression test. No compression on 1,2,or 3. Normal compression on 4.
His guess, burnt valves from a plugged cat converter. (not yet confirmed)
Replacement cost for a used engine $3600 - $4400.
What to do???
Car has 160,000 miles and is located in Western Canada.
What to do???
If just the valves are bad you could get a used head for $200 or less, found some for as low as $135 on car-part.com in Ontario.
And I'm hoping that your quote for a replacement engine includes installing it, because that is pretty steep.
If I spend money on it, I want a permanent fix..... Honda's aren't supposed to ever break.... <grin>
Yes, I'll have him run one.
Compression reading based on memory were
1. close to 0,
2. 0,
3. 0
4. 160 psi (its amazing it still runs)
I was 3 hours into a 24 hr drive and just begging for some second opinions, when I stopped into this independent shop. I was into his bay within 10 min of limping into the parking lot and within an hour we were to the conclusion that this car wouldn't be making any 24 hour trip. Car is parked there and I'm back home and sad....
07 Accord 4cyl EX-L MT
1. close to 0,
2. 0,
3. 0
Oh well, now I fly out tomorrow. I was planning on being there for some time and wanted my own car there, not a rental....
At the first opportunity to find help, I exited and at the first red light the car would hardly idle, but surprisingly it would still start when shut off. Codes in the computer were missing on 1, 2, and 3 but 3 was the worst. And cat converter problems....
I've only had this car for less than 3000 miles. I had an 06 Accord exactly the same with 80K miles on it that got rear ended last summer and written off without even any lights being broken. Underneath the floor of the trunk was crumpled, but the car was still driveable. I could have kept that written-off Accord for $1100. This one was purchased used to replace it, so I don't know how it was treated. I should have kept both of them, except the WAF was zero for keeping the junker.
Oh well, you pays your money and you takes your chances....
