07 Engine blown - 4 cyl EX-L 5sp manual
Old 05-01-2014 | 02:51 PM
Rob2000AccordLX's Avatar
I would get a second opinion. Something doesn't sound right. Maybe the timing belt broke? Do you know if it was ever replaced?
Old 05-01-2014 | 05:05 PM
The car doesn't have a timing belt. It has a timing chain.
What may have happened was that the car was ran with low oil levels or infrequent oil changes over a period of time, which can cause the timing chain to get stretched. Which over time, can also cause damage to the engine due to bent valves, etc.
When there is a flickering or blinking Check Engine Light, you shouldn't continue to drive it. A flickering/blinking Check Engine Light is not the same thing as a steady Check Engine Light being on.
vetski179
08-19-2015 09:32 PM
davntaz
04-11-2015 10:10 PM
j894
04-18-2013 06:59 PM
linden
12-09-2012 01:09 PM
az4438
10-28-2011 09:30 PM
