An 11 degree morning and my 97 Accord desides to overheat! lol
In my experience, Accord won't overheat while driving due to lack of cooling fans; ie air flow from foward motion is adequate to cool engine. That means either low coolant or thermostat. Low coolant seems unlikely from your inspections, and you are replacing thermostat (use OEM for best warmup time).
ok, ive not run into anything other then regular runny coolant, but i guess from your description i woulndt see any slushy stuff right? I have the thermostat replaced but the hose from the airbox to the throttle body is ripped on the ridges along the body so now I have to get that replaced. My local auto parts places dont' carry it and I want to avoid the dealer. Once I get that replaced then I can test drive it and see if that works. At least Ive replaced a VERY old part. Thank you again.
As for the fans, if the radiator is clogged, then no amout of cooling fan action is going to help.
Suggestion: Anti-Freeze testers are pretty cheap at auto parts stores; you might want to consider buying one and testing the coolant so you can either rule this option out or confirm that it is a potential issue.
So here is the most current status. I have changed out the thermostat, taped up the cracked intake hose and reassembled everything. I topped off the coolant with 50/50 mix from O'Reillys to the top. I then started the car with fan and A/C off and radiator cap off. I let it get to operating temp with the cap off and had a lot of bubbles coming out. When the bubbles stopped I put the cap on and took the car on a 4.5 mile drive, 55 MPH +/- and on a very steep hill close to my house. It stayed at the typical temp location just below halfway on the gauge. I let it idle in a church parking lot halfway thru my trip as well. It seems to be operating normal now, but who knows what I'll find on my drive to work as it's 50 miles.
As far as the coolant freezing, I'll see if I can find a tester and report back. How will this tell me if it was frozen?
Would a block heater help with preventing this? I have never had my coolant freeze before, even when I lived in Colorado so this is odd. I live in Missouri now. The only part of my routine that changed is that I rarely go start my car and let it warm up before leaving. I go in, start it, put my seatbelt on, find a radio station to listen to and then gently head out. I don't gun it or anything, but this morning I let it idle for about 6-8 minutes before leaving.
Thank you again for everyones quick help. Have a good day!
A block heater will not help, and "warming" up the car before driving typically won't help as well. You're doing it correctly, start the car, click on the seat-belt, check the mirrors, put it in gear and drive away at a conservative speed until the squirrels under the hood are warmed up.
nickmg555
12-22-2013 08:02 AM
qpon808
04-11-2007 02:55 AM
